Discuss Combi Boiler - Potterton Puma 100e - Fluctuating temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
willingnotable
Hi guys, Over the last few months I noticed that the hot water temperature in the shower has been fluctuating from very hot to stone cold every few minutes. Thought it was the thermostatic shower control but decided to check the boiler first. Boiler pressure is 1.5bar, mains cold water supply and pressure is good and constant. So, I ran the kitchen hot tap at full flow and measured the temperature. The boiler clicks on and water heats up to 53c, then boiler cuts out and temperature drops to 41c before boiler clicks back on and heats up again. This cycle continues all the time the tap is on. I set the HW temp dial on the boiler to min - same temp range happened. Set it to max and the boiler heats water to 65c for a couple of minutes then cuts out and down to 41c we go again. I did the same test at bathroom taps with same result. Questions:- 1) Is this normal combi boiler behaviour? 2) If not is this a common problem with a common solution? 3) Can this be fixed by the relevant component (whatever it is) being replaced or is it new boiler time :( Any help and advice appreciated, thanks.
Reply to Combi Boiler - Potterton Puma 100e - Fluctuating temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
