Discuss Cold water to shower no longer running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys!
ok,was called to a job today,homeowner had a slight leak under his kitchen sink on Tuesday,he switched mains off overnight & replaced washer in the morning,in between then his son & wife had a shower (separately!!!) it's thermostatic & is tank fed.Now after turning the mains back on,the shower was used again,ran normally for 30 seconds or so then flow stopped.
So I've went round tonight & the hot seems ok but there is nothing coming through the cold,even though the whb & bath taps are fine along with the wc.The house is set up funny,it's a 3 story building,the customers house is 2 stories & there is a flat above,I've tried using the hot to push any air back up to storage cistern,cleaning shower cartridges,running the water with the shower disconnected but there is only a trickle coming through!!now I'm going back tomoro & am going to go up into the attic to see if there's a valve that's been shut or if the shower has it's own feed from the tank & is maybe blocked with sediment etc.
Is there anything else that may be causing this?!i know it sounds like an airlock but I can only try removing it with tank fed hot water!! I really don't think there will be any shut valves & am not even sure if there will be a separate feed from the tank!!
This is really bugging me!!
cheers for any help!
As above or disconnect the cold main to the FOV and attach your hose, poke it down the cold feed and run the main whilst the cold outlet is open.
Ahh I thought maybe float operated valve!!
thats what I done anyway,connected into the mains at ballvalve,fed bit of pipe into outlet for bathroom and turned on mains,water now perfect!!
thanks again guys,much appreciated
Yes you was right, FOV.....float operated valve.
Welldone it's a good way to do it.
Reply to Cold water to shower no longer running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
We have a pumped shower with a thermostatically controlled mixer valve. My wife complains that when she is having a long shower (hair wash etc)...
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header...
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
