Discuss cold water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
choirfran
Hi I have a problem with the cold water tap in my bathroom. All the other taps work fine but suddenly there is no water coming out of the cold tap on the sink. I have checked the filter on the end, no broblem there. It is a 2 tap 1 spout type. Please can someone advise me what I can do.
Air lock
Try holding your hand over the spout & turning the tap on. Hold it for a while & see what happens
As above, you could try holding your hand over the spout end and opening both taps and hold for a few seconds. Be careful if the hot water is very hot. It is worth a try, but these modern mixer taps don't usually mix the water like the old taps did.
You could also just have a faulty cartridge on the cold side. Washer could be stuck, or works have slipped apart inside and needs stripped, some silicone grease and put together again if you are lucky
Reply to cold water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
