Discuss Close couple bolts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TBServices
Anyone know where I can get replacement bolts and washers for a bolt through close couple cistern? Got a toilet to repair and the old bolts are rusted up to the max.
Local suppliers no good and can't even find them on Plumbfix
Buy a box of M8 stainless steel bolts and a bag of 3\4 tap washers and they'll do countless jobs for about £6 from Screwfix
Much as I hate to say it, BES are OK. We have used them for odds and sods for years.
Sticks in the throat a bit though. :(
B&q have them on the shelf for about 3 quid. Pts do them for about 2 quid.
Reply to Close couple bolts in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our builder set up the soil pipe and supply for the closed couple toilet but says it's actually impossible to connect to the wall securely (ie he...
Hi there. I have a Cersanit close coupled toilet which as started leaking between the cistern and the bowl when flushed. I've taken the cistern...
Hi - I have an old (maybe 45 year old) Twyfords Close Coupled toilet. The cistern has cracked, and I'd like to replace just the cistern. I'm...
Hi. Water is slowly leaking into the toilet bowl from the cistern. I suspect that it's the rubber washer at the bottom of the tube that's the...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
