Discuss Cleaning 10mm Plastic Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hello all,
Quick confirmation question!
I am currently getting quotes for central heating, looking to do most of the work myself to save money. My current system is 20 years old, with an old Ideal Elan 2 boiler, and a "Mainsflow" hot water cylinder. I've had some issues in the past with blocked pipes, but have cleared them by removing the fittings, and rodding using an electricians nylon fish wire, sounds rough but it worked, and I've been in the house 10 years.
Anyway, in my head, I want to know that the pipework is clean, before spending on a boiler, and being wary of powerflushing I was looking at alternative ways.
One plumber has suggested, as I'm wanting to upgrade everything, to fit the new boiler first! (W/B 34 CDI) and use the filling loop to pressurise the system and blow each set of pipes through for each radiator by removing the rad, and connecting 2 waste pipes and running outside. I like this idea, because it confirms each one individually.
The other other issue he has suggested, is that as I have a "Mainsflow" hot water tank, he can't guarantee what pressure it could take?
Does this sound reasonable? I was hoping to be able to prove all the pipework, before having to spend on a boiler?
Thanks in advance
Jay
If the system is 20 years old why not replacing everything whole new system is the Only way to guarantee everything is clean
Most the sludge settles in the rad so you'd have to flush rads through with hose outside also for best cleanse!
Fit a Magnaclean, do chemical flush & drain, refill with x100...
Good boiler choice too with the 34 Cdi classic :)
Please register with us to receive additional answers to your question.
To prove all ye pipework and rads are sound I would pressure test them using air or hydraulic ie testing with water pressure
Thanks for the replies, I'm not suggesting anything misleading by this plumber, but I wondered why it was necessary to fit the boiler before I could prove the system.
My neighbour has exactly the same system, and he's been in the house since construction, and other than an upgrade on his boiler, it's original
I understand suggestions to renew the pipework, but I don't have the money to do it, and why would I need to if next door is proving it can work.
I am going to renew all rads and valves, I've had a Magnaclene fitted not long ago so I just want a good way to clean the pipework
Your suggestion looks favourable Gassafe, any other tips?
Life span of plastic pipe is around 25 years
If you want to clean the pipe work properly then a power flush is the best way
Reply to Cleaning 10mm Plastic Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
