Discuss Clay Dainage Pipe Blocked in the USA area at PlumbersForums.net
Hi all,
Bought a doer upper which hadn’t had any maintenance for years.
Front facing wall of the house was like a marsh around the grid above a clay drainage pipe which the kitchen sink/washing machine fed into.
After I scooped about a foot’s worth of water out of the claypipe, I’ve found what appears to be a blockage which is grey and compacted (only way to describe appearance is it looks like plasterboard adhesive mixed up). I can scrape the surface of it with something sharp and and a little bit scrapes off but the rest is in solid. Any water going in has been draining into the surrounding soil through a joint in the pipe (where the green arrow is).
What is the best method of removing this blockage? Jet spraying, boiling water etc? Not sure if rods would be able to dislodge.
Further info: Property is semi detached and the clay pipe at the blockage area turns 90 degrees towards the neighbours side and i assume joins their pipe (as they have the exact same setup) then again I assume at the party wall join it turns 90 degrees inwards to tee into the main sewer pipe running underneath the foundations of our properties.
Reply to Clay Dainage Pipe Blocked in the USA area at PlumbersForums.net
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of everything it appears that there is no water coming in, its mains fed and no sign of leak anywhere , we have checked the isolation valve and its not faulty...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains pressure from small hole/crack The outside of pipe (measured with veneer caliper) at 23.5mm Pipe Runs under drive, along side of property and looks to go...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing with it as a matter of course. If I'm wrong can someone let me know and I'll shift it to a better place.] I have a condensing boiler installation...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or garden, run-of-the-mill British housing estate CH setup. Downstairs radiator, 1 of 2 in our living room, went cold one evening mid-November last...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone shower in the garage which has been removed. Unfortunately the pipes are only 1.5" on that side of the house since there's no bathroom and the house is...
