Discuss Cistern 15mm male inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eltel35
I'm trying to fit a new close couple toilet. The inlet is a threaded 15mm pipe and I'm struggling to find the right connection to hook it up to 15mm pipe. I tried flexible hose with a half inch connector but it doesn't fit. The only other imperial sizes seem too big or small. I must be missing something obvious because it's not an obscure make (Vitra S50) but I could really do with some pointers. Many thanks.
pictures would help. the thread will be 1/2 inch not 15mm by the way. how do you mean it doesn't fit? can you not get the thread to start?
Hi, thanks for the reply. I've taken pictures but the forum won't allow me to post them.
The hose connector seems far too big. I'm now wondering if the wrong size is in the packet. It says 15mm x 1/2" x 300mm, but it looks much larger than that when measured.
Picture at i.*********/Nwyrpskh.jpg
http://i.*********/Nwyrpskh.jpg
Inlet picture i.*********/rUkC0Loh.jpg
http://i.*********/rUkC0Loh.jpg
15mm flexis should fit the vitra no problem but like chalked n steve said it may be threaded and unfortunately because its plastic its easy to mince the threads, if your very carefull you might manage to salvage , just take your time and try and re thread but if you cant then it is possible to cut out the bad threaded piece and attatch flexi but your cut has to be perfect and square, otherwise youl need a new water inlet ( fluidmaster or similar ) which is a straight forward swap, (unless its side entry),
Ive had the 3/8s ones aswell, (foriegn tinternet) i had to buy a 3/8-15mm brass bush then flexi the vitras are 15mm
Thread is fine, the connector is just too big. All of my replies are being held for moderation I'm afraid.
looks like 3/8 to me pal you need a 3/8 connector to 15mm so get a 3/8 to 15mm female iron strait
http://m.NoLinkingToThis/p/fluidmaster-euro-bottom-entry-fill-valve-3-8/87426
I know vitra have a few different models ( s20 s50 etc) but any that ive fitted have always been 15mm
If it's 3/8 ? And you want to use a flexi. Screwfix do a 3/8 to 15mm hose.
WRAS Hose 15mm x 3/8in x 300mm x 10mm | Compression Hoses | NoLinkingToThis
It might be a continental 10mm or 12mm fitting on toilet fitting,float valve, might be easier to take it out and bring it to a plumbing shop and they will give you a fitting to get up to 1/2 inch!
Reply to Cistern 15mm male inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
