Discuss Chasing pipes in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Can anyone recommend a decent pipe detector to detect pipework in concrete floors - I need to chase a pipe this afternoon and don't fancy chasing through other pipes!!
Or if anyone can recommend another way??
Especially if it's a water pipe, you could try thermal imaging.
You can hire a cat and Genny from any hire shop we used them to trace services, bit of over killl maybe but it will pin point the pipe, top bit of kit.
Hit a gas pipe the other day that was buried, all carefully measured out and the idiot who put it in, put it on an angle. Ruined my Wednesday.
Reply to Chasing pipes in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What is the recommended way to conceal a 1.5M, 40mm shower waste pipe? We have 30mm gap behind the plasterboard which will be renewed. Would you...
Bungalow built in 2001. All copper pipework (water and heating) runs in channels of expanded foam polystyrene between a concrete floor and OSB...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
