Discuss Changing External Thermostat/Controller for Vailant Turbomax 242E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
anarack
Hi - I have an old 'Smiths' electronic controller that keeps failing so I have purchased a controller/Thermostat to replace it, based on direct control of electrical heating using electronic relay I believe.
The wiring diagram for the Turbomax shows switching contacts between terminals 3 and 4 on the boiler terminal strip - however, the output from this type of controller shows 'Load' which suggests that it will sink current directly (up to 16A). If the boiler wiring is switching a L voltage across the two terminals then this is probably fine, but I do not want to damage the circuit board by trying it on the off chance! If need be, I could fit an external relay unit to the controller to act purely as a switch.
Has anyone fitted this type of Thermostat/Controller please, or do you know if the circuit on the turbomax will work with this configuration?
Reply to Changing External Thermostat/Controller for Vailant Turbomax 242E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, hoping someone can help with a problem that's been perplexing me since just before Christmas..... I have a wet underfloor heating system...
1K
AFAIK the boiler is set to fully pumped. (The switch inside is on fully pumped), however the pump is only running while the boiler burner is...
Our current heating system has a Potterton EP2002 controller and Potterton Prima 60F boiler. I have bought a Wiser multi-zone kit 2 plus a number...
2K
Morning Ladies and Gents, I'm after a bit of guidance regarding the Nest thermostat 3rd Generation please... My heating system is a Glow worm...
2K
Objective: I have an existing s-plan plus (see below for details) heating and hot water system, with 2 independent heating zones. There is a...
3K
