Discuss Central heating/hot water pump problem. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BigAl
Hi there, I decided last night to check my heating system before it gets too cold, and unfortunately I have encountered a problem.
I have 4 radiators heating my flat and have a Grundfos selectric 4, Type 450 - 130 pump, probably 30 years old, the problem I have is that it isn't pumping.
I have checked the rotor and it is free and the motorised valves are operating.
When I turn on the central heating and hot water switches the motorised valves operates but the pump doesn't operate. I have removed the cover on the pump and checked for a power supply, the power is present, but when I turn off the central heating control switch the motorised valve shuts down the power stays on at the pump, the same applies to the hot water switch. If I turn the mains swicth off and on again the power to the pump has gone. when I operate the motorised valve switch and it opens fully the power comes on at the pump, but when I turn it off the valve closes but the power stays at the pump, and the pump is rather hot. Is this a symptom of pump failure. If so can you recommend a replacement type?
Many thanks
If you've got 240v to the pump [ live - neutral] & the rotor's not spining ypu need a new pump.
A grundfos ups 15-50 should do, or a similar 5 metre head pump.
Regards the power to the pump after valves shut, it'll be the pump overrun.
Makesure you turn off the electrics off & remove fuse at the fuse spur before changing it.
Cheers aggis, I have replaced the pump but before I run the system I was wondering... when bleeding the radiators do you do it with the pump on or off?
On ... or off!!
Best with it off though, until you think they're all bled. Sometimes the pump is needed to push some air around to an upstairs radiator.
OK pump working fine radiators all piping hot, but.......When I turn on the central heating switch the motorised valves operates and after the time delay the pump fires up no problem there, but when I turn the central heating switch off the pump keeps running. (Probably why the original pump packed in)? I have to turn it off at the mains switch, but if I turn the mains switch on again (without the central heating switch) the pump runs for approx 5 seconds and shuts off. This happens with either hot water or heating. I have checked the same system next door and as soon as you turn off the heating or water the pump stops immediately.
Any ideas on this issue
Hi al , the suprima controls the pump and it is pump overrun you are experiencing , this is correct and should run for about 5 mins to clear residual heat to protect the boiler
Brilliant thanks ferret, that has saved a pensioner an expensive callout. I never realised there were so many helpfull people out there. Once again thanks to all who helped, magic site.
Reply to Central heating/hot water pump problem. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
