Discuss Can't turn off central heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear forum
My problem is I can only turn the central heating off and on by the main switch in the airing cupboard
The program timer is Siemens RWB29 it all lights up I have just put in a new cell battery
Or do I need a new HSA2 or could it be the thermostat sitting next to the programmer
Any help would be good
More than likely the 2 port is stuck open which means the microswitch inside is making the connection between the grey wire(permanent live) and the orange wire (switched live to the boiler).
You may get away with taking the actuator head of and moving the valve spindle manually back and forth to free it up but this will more than likely be just a temporary fix. A new valve is the way to go and i would suggest a system flush while your at it, as dirty primary water could well be the cause of the valve sticking open.
Hope that helps
Reply to Can't turn off central heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
