Discuss Can you use construction board instead of Tile Backer Boards in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Found this. Just wondered if it can be used instead of tile backer boards.
I realise that I need a 1wmm board to make up a gap between wall and shower tray, but the STS tile backer board is only 10mm. I did consider dot and dab the tile backer to increase its thickness
ta
Reply to Can you use construction board instead of Tile Backer Boards in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
