Discuss Can I? Impeller pump in the USA area at PlumbersForums.net
Deleted member 113604
Hi all. I have a single occupancy house with gravity feed hot water.
The hot cylinder is downstairs with a cold water tank in the loft.
The hot comes straight out from the cylinder then 90’s up to the first floor bathroom tap, then the bath & back downstairs to the kitchen sink. There is no flange or branch to a vent pipe from the cylinder. There is a vent/overflow pipe to the cold tank which as far as I can see is somewhere on the hot run after all the taps. Can and is there a pump I can use to boost the hot pressure? With out having to worry about a flange or where the overflow is situated? Ideally I’d like to put the pump after the bathroom sink & before the bath( under the bath) if not on the vertical run up from the hot cylinder. I’ve looked at the Grundfos ssr2 & the salamander ct55 but worried about the air bubbles from the cylinder being a big issue. Any advice would be appreciated. Thank you. Tony
If I've understood your description then no you can't put a pump on the hot water system as it is.
You will need to put an open vent pipe in before any outlets or go for an unvented system or maybe some other potion.
Best to get a plumber to take a look and advise what your best / most viable options are.
Reply to Can I? Impeller pump in the USA area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
