Discuss Can I add another pump? in the Ireland area at PlumbersForums.net
Just after abit of help really
I've installed a 35kw Worcester system boiler in a property, over the last 6 months the customer has purchased the house next door and converted 2 houses into 1.
A lot of the pipework I couldn't get in to check/change due to various reasons but the primary run is 22mm all the way as far as I can see with branches of 15mm.
There is 24 radiators on the system of which 6 are small towel rads all upstairs except the furthest away get red hot and all downstairs bar the 3 furthest away get hot if I turn 4 or 5 years off the ones furthest away belt round but as soon as the others are open again it loses the heat
I've shut down all lockshields as much as I can which helped slightly but not enough
What I'm asking is can I install another pump onto a system boiler down the far end of the property where it's struggling to get to and how do i go about doing it?
Reply to Can I add another pump? in the Ireland area at PlumbersForums.net
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
