Discuss Can anyone recommend a good tap spanner? in the Plumbing Tools area at PlumbersForums.net
currently an apprentice and just changed over some basin taps my tap spanner isn’t great and slips off a lot, can anyone recommend anything decent and not too expensive?
thank you
Armeg jaw dropper are the ones I use the most
If it's a basin spanner - as per link by Moonlight, they take some getting used to.
All fairly much the same design, it comes down to the teeth on the jaws and also the user.
They are an awkward tool to use and require some practice in using them.
I have the monument tap spanner, and a crows foot (both have been useful) - the latter doesn’t see much use, but I use the monument on the Vaillant prv nuts if they’re a bit stiff. Rothenberger one’s are supposed to be good. I haven’t and probably won’t go for the Armeg - tighter than a ducks proverbial.
Reply to Can anyone recommend a good tap spanner? in the Plumbing Tools area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
