Discuss Can a faulty faulty tap cause low water pressure. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nas
Hi I got called by a customer today to try and fix low water pressure on his hot water bath tap (its a shower mixer type fed from a water cylinder). All the pipework looked ok to me. So I disconnected the flexi pipe connected to the tap. I checked the pressure going in and the pressure seems ok. So he the tap must be causing the problem right???
Is it possible the a double check valve may fix this problem?? I've got a feeling the cold water pressure through the tap is affecting HW pressure.
if its a mixer tap it should have check valves anyway. give it a go its a cheap enough option to try, and if nothing else it will give wras compliance and eliminate a possible cause.
KJ
Hi. Found out a bit of history of the situation (did it work ok once?) As the flex hose often start to break down and impair flow.
Reply to Can a faulty faulty tap cause low water pressure. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
