Discuss Bypass Valve on S-Plan Installation CH system in the USA area at PlumbersForums.net
Just a quick one folks.
Should there be a bypass valve at the ringed location in the attached picture?
Between the pump and the CH/HW valves?
Depends on boiler manufacturers instructions.
There is no explicit mention of bypass exclusion. There is an arrow on the pump that indicates flow from right to left from the boiler. But that boiler connection at the rear of the boiler that the pump is connected to is described as the Heating Return which would suggest the opposite flow. Confusing. So there doesn't appear to be a bypass valve. I'm guessing that the gate between the white Reliance valve and the HW tank is just an isolator.
If it has pump overrun yes should have an auto bypass
Need an auto bypass fitting then else the one you have is always open
Reply to Bypass Valve on S-Plan Installation CH system in the USA area at PlumbersForums.net
A plumber recently told me my bypass pipework is poorly designed as it’s offering a low path of resistance v the motorised valve T junctions, and...
2K
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
I have read that an Auto Bypass Valve (ABV) is not compatible with a pump set to Proportional Pressure (PP) mode. I have a recently fitted...
2K
G
HI folks, is it possible/feasible/reasonable to insatll an ufh manifold and system (for a 17m2 room) from a disused CH 15mm flow and return? I...
