Discuss BSP Threaded right angles orientation. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chris Lyon
I have a fair degree of experience with 15/22/28 mm fittings in both compression & solder but I am now fitting an UFH manifold which has flow and return presented in 1" BSP fittings. All fine, I have various of these fittings that convert to 22mm compression. All would be lovely if it wasn't for the fact that one of them is a right angle fitting ( the hot flow enters from the bottom of the mixing valve whilst the return exits on the horizontal. Tightening this right angle 1" to 22mm fitting ends up with the right angle pointing in completely the opposite direction from which I want it to go. I could use lots of PTFE tape or boss white or such, but I was hoping there is a actually a procedure for such a situation, would for instance a fibre washer correct for this by being a half turn pitch or does one just tape and adjust amd tape and adjust till it all comes good?
:Iagree: loctite gives you that bit of flexibility and you'll find the fitting tighten's that bit sooner :)
Agree with the loctite55 advice if not can you not use a straight male iron to copper and a street elbow...regards Turnpin:punk:
The same thing happens on many situations when tightening in a male bend - like on top of a cylinder. If there are at least 4 or 5 threads on the female & male fittings, then ordinary ptfe tape at the correct amount will seal the fitting no problem, even if it can't be fully turned. Enough tape to make the fitting feel tight to turn with a spanner & some Jet Lube sealant over the tape first.
I tend to tighten a male bend on without any jointing to see what angle it tightens to. That way I know if I need to add extra ptfe tape to the shoulder of the fitting. Locktite 55 seems the way to do it though.
Reply to BSP Threaded right angles orientation. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from...
Hi all I'm blanking a couple of openings in a hot water cylinder. The Screwfix Flomasta 1" BSP plugs fit perfectly but no washer supplied or...
Morning all. I hope this is the correct place for this post. If not i'll happily move it to another forum area. I am renovating a property and...
I have a towel radiator that has a tiny leak on the lock shield side at a right angled compression fitting. There is a drip every 10 seconds from...
Deleted member 120897
Hi all, I need to order a flexible pipe to connect this vessel up with. The pressure vessel instructions don't mention the thread size? A 22mm...
