Discuss Do I need a washer for blanking plug in a copper hot water cylinder? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all
I'm blanking a couple of openings in a hot water cylinder.
The Screwfix Flomasta 1" BSP plugs fit perfectly but no washer supplied or listed.
Given that the element has a washer and everything else is a compression fitting I'm concerned these should have one. The alternative is PTFE tape or La-co (as well as washer if not instead of).
Does anyone have a definitive answer please? Given the blanks will be hard to reach it's definitely a job to get right first time.
Ptfe tape is required
Reply to Do I need a washer for blanking plug in a copper hot water cylinder? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
