Discuss Broken soil pipe sealing ring - any ideas? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a 110mm soil stack which is completely boxed in, it has a branch coming into the bathroom for the toilet this branch ends in a push fit seal which a solid pipe fits into. The ring seal on the end of the branch is broken and therefore the rubber doesn't hold the pipe securely. Is there a way to replace these? I can put the rubber seal round the pipe and fill in behind it with silicone and it would probably hold but I'd like to do a better job, can't dismantle the soil stack though.
Any help appreciated
Peter
Any chance of a few pics of the broken pieces
Yep spot on two options
https://www.NoLinkingToThis/p/mcalpine-dc1-bl-drain-connector-black-110mm/4255v
Or you could glue a piece of 110mm into the socket
Or option 3 , if you can identify the make and the design hasn't changed, you could buy a coupler and use the seal and ring from that.
One or 2 ifs and buts in that tho'.
Reply to Broken soil pipe sealing ring - any ideas? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
It's not every day I deal with 110mm soil pipes, therefore I do not have a selection of different fittings at hand to try what combination fits my...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
Fitting a new toilet onto this old cast soil pipe that only fits in about 2inches. It's coming through the wall at an angle and can't be changed...
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
