Discuss broken screw in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
my toilet pan sits on tiles , while trying to move my pan one of the screws snapped , i now have a very tiny piece of screw above floor level and the rest of the screw is stuck in the tile/floor , any advice on removing it ? , iv'e tried pliers but no joy . thanks .
One way if you can get a combi on it tighten up the chuck around the screw then reverse it gently out.
Hit it with a hammer to make it flush and re drill the hole
Reply to broken screw in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
