Discuss Broken head on TRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wickers
I need to remove a radiator for decorating. The head on the TRV has snapped off so that the pin is exposed.
Does this mean that the TRV is open so that water will flow through it or will it be shut closed so no water will flow.
(I cannot loosen valves and lift radiator off brackets and lie radiator on floor as the pipes are tight in the floor.....just in case anybody suggests this idea).
Thanks for your help.
Wickers
There open.
If you have the box which the TRV came in it should have a white cap in it. If you place that on the head that will shut it off. I always leave these with customers when fitting new TRVS incase they want to decorate.
Temporary fix with tiewraps, jubilee clips, string, or child with stick, not recommended to hold the pin down, it will release when you least expect it.
You'll have a temporary closure cap somewhere, you just didn't realise what it was for.
I should add that it's better to use the closure cap if you've got it as the trv can open up and let by if the temperature drops.
How do I know this?
We had a Welsh plumber called Di (afterwards known as Di the Leek) who took a rad off and only used the trv to isolate the water. Did I mention that this rad was on the first floor? Anyway, it being winter, the temp dropped and the valve opened, water poured out and dropped the kitchen ceiling and then carried on into the basement, dropping that ceiling onto a brand new massive tv and lifting the recently laid oak floor.
Our boss's insurance took a hammering that day!
John
Reply to Broken head on TRV in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hello, we have bulldog trvs on all our radiators but have a problem with 2 of them. The 2 upstairs radiators do not turn off (4 downstairs all...
1K
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
