Discuss broken boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
louisqaz
HI NEW TO THE FORUM , WE HAVE AN APOLLO 30/50 B GAS BOILER THAT HAS STOPPED WORKING, IT KEEPS BLOWING THE 3a FUSE, AND I CONNOT GET THE PILOT TO LIGHT, THE LAST COUPLE OF DAYS IT HAS MADE A CLUNKING SOUND WHEN IT SWITCHES ITSELF OFF , COULD ANYONE POINT ME IN THE RIGHT DIRECTION THANKS
Power cable has been run along the flow pipes and has melted through causing a short circuit.?
sounds like it could be thermocouple or interupter fault for pilot light not to hold.
if the fuse is blowing dont worry about lighting the pilot as it wont work until you find the cause of fuse blowing it could be numerous things ,dont be tempted to remove the cover ,it could be your pump or zone valve or something external that is causing the fault maybe check for water leaks around airing cupboard
Thanks for the advice i will have a look in the morning i hope it is something simply
Reply to broken boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an old Modena 80 E combi boiler that is randomly short cycling on windy days. The burner goes out and re-ignites within a few seconds and...
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
Hi, Am trying to understand my mother's Apollo boiler. It has an intermittent fault. In the last couple of years, it has had a new...
