Discuss British Gas UP2 Dual Programmer issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nasreen Cullen
Hi
I recently moved into a new house that has a UP2 dual programmer.
Whilst we seem to have no issues with hot water, I cant get the central heating timer to work and the on function seems to work sporadically.
Any "a dummies guide to.." type help would be greatly appreciated.
Nasreen
None of our radiators heat up on the timer - I went through the settings today and despite getting a green light to show it was "on" there was no heat.
I currently have the programmer set to "on" which has worked once or twice before, but right now no heat.
Hot water is fine - its set to once - i believe and the boiler itself whilst old is working.
I did recently turn the boiler thermostat down to 2 from 3 (not sure if that would cause an issue) but all else seems ok.
Do you have a thermostat one a wall somewhere, usually in the hall way. If so is the temperature set at around 20.
Havent bled the radiators - that was on the list if a possible solution.
Havent tested with water off - tbh scared to incase water doesnt come back on, but I will try it.
And no, cant see a thermostat - I dont think there is one. There is a heat "selector" on the tank in the airing cupboard but it doesnt look like a typical thermostat.
Reply to British Gas UP2 Dual Programmer issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
