Discuss British gas stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
learnplum
Hi does anyone know the make of a common wireless stat by british gas?
Its says british gas on the stat and receiver.
Its an oldish wireless stat and programmer.
I know it if I see it, but can,t find it on the net.
It has 4 batteries.
Lost the bloomin make in the van.
Need to reset it tommorow, on a void property.
Thanks:tounge_smile:
:blush5:I no ch4, sorry I sometimes kick my own dumb bum.:blush5:
They use Drayton stuff. I know the stat you mean, two draws left and right side. If you are just changing the batteries and its not dead you'll be fine. If it's dead. Hold both buttons on the reciever for a few seconds until they flash slowly. then push in the left draw followed by the right, and increase the temp. That should do it.
Is this what you mean??
I thankyou both, I can,t thank you both enough.
That is the one.
Any tips on setting it up?
What is the part or reference no.? thanks?
I will read it:blush5:
Reply to British gas stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
