Discuss Bristan separate hot/cold Kitchen Pillar Tap Washers in the USA area at PlumbersForums.net
hi
as our separate hot tap is dripping contacted Bristan to ask what washer to get as heard that depending on date bought, washers either rubber or fibre. Bristan said that they do not supply individual washers but only complete valve assemblies. sure that I have seen Bristan washers on the internet for pillar taps both rubber and fibre. Do you think that if I replaced just the washer and not the valve assembly this would cure drip. still unsure what to get, rubber or fibre but taps bought after 2006.
Many thanks
1. If your tap takes 1/4 of a turn from off to on / on to off, you will need a new cartridge.
2. If it takes multiple turns to go from on to off it will require a rubber washer. As far as I know there are no taps with flow control washers in fibre. Some do have fibre washers in their connections to the water pipework.
Reply to Bristan separate hot/cold Kitchen Pillar Tap Washers in the USA area at PlumbersForums.net
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
I have a quarter - turn Cold Water Kitchen Sink Tap that has a started dripping and i am trying to gain access to the washer/valve assembly and...
When changing bath taps does anyone use the 3/4 flat washers you get with hep20 tap connectors instead of fibre washers? I use the 1/2 inch hep20...
2K
Aquarius
A
I have a dripping Franke Mythos quarter turn kitchen tap. It seems that the two part washer element are not replacable and I have to replace the...
R
I have a quarter turn cold water kitchen tap that has a slight drip and cannot see if the valve assembly is removed from the top? ---- there is a...
