Discuss boosting cold water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
what's the best system to use to boost water pressure for a commercial setup? caravan toilet block feeding 6 showers , 6 wc and 6 basins, I'm fitting 2 riennai water heaters. there is poor flow and pressure on site, what's the bet way to maybe store and boost the water pressure? thanks
Break tank and pump
Your looking at approx 4-6 bar and a good 50-60lpm
Thanks shauni did not know it would be not enough. Thanks for letting me know. I thought dAB system could be enough as you can attach as many tanks as you want
Yea it's the pressure curve think it does about 3.5 bar and 30lpm
Dab esybox. 3.5 bar 120 lpm quiet and powerful
Not quite 3.5 gets you around 80 lpm
1 bar gets you 110 lpm
You would need the dual riser kit / dual esybox
Reply to boosting cold water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
