- Messages
- 34,374
- Solutions
- 2
Turn your hot water booster pump on does it still overheat? You might need to run a tap
Discuss Booster pump installed successfully, but now boiler goes to overheat! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It is open now, yes. How do you check actually if the valve is faulty, only by taking the connection apart?
Reply to Booster pump installed successfully, but now boiler goes to overheat! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
