Discuss Boilermate 2000 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gjlatz
Hello all,
I'm going to attempt to change some taps in our house, however the house has a mains pressure throughout hot water supplied from a Thermal Store.
My question is. In order to change the taps do I simply turn off the mains supply (under kitchen sink) drain the taps and then change them. Or is there something else that has to be done with the thermal store?
Many thanks
Gjlatz
Turning off the incoming mains should do the trick! be sure that your workin on the mains and not a balanced cold because some times people do real silly things when piping a pressurised cylinder.
Thanks for the reply Hugh. The house is 7 years old and info regarding the water supply is that it's mains pressure.
Reply to Boilermate 2000 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
