Discuss Boiler queries - Worcester Bosch Compact in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mo7
I have been trying to decide on what boiler to go for - I think my head is about to explode - but I have to make a decision.
Some background - I have a combi boiler - 4 bedroom house with 9 radiators (of varying sizes - 3 big doubles and the rest singles)
My current boiler is an Aristion Clas HE with 24kw output and 10.3 water flow rate.
The current boiler has been fine for central heating/radiator purposes but average for hot water. I am replacing the boiler and moving it to a new position and will be running a shower off the boiler instead of the current electric so concerned about water flow rates.
After much faffing I have decided to go for a Worcestor Bosch. My decision is between the normal sized 34CDi and the Compact 36 or 32.
The stats:
34 CDi - 30kw and 14.3litres
32 Compact - 24kw and 13.1 litres
36 Compact - 24kw and 14.7 litres
I wanted to go for the Compact because they fit in a kitchen unit and long story short the perfect place is in a kitchen unit right near where the mains comes in. If I go for the 34CDi I will need to move it elsewhere which will cause me a lot of hassle in having to get units in for the kitchen and shifting the kitchen around.
So my first question is - do I need the 30kw or can I stick with 24kw. I am retaining the same radiators (maybe even losing a small one). If I can get by on 24kw then I don't think I need to upgrade. I did an online calculator which suggested I needed just over 6kw for my central heating. I understand the 24kw is the maximum and only some is for the central heating - rest is for the domestic hot water.
I understand that the KW does not make any difference to the actual heat of the CH or HW.... is that right? As it is the boielrs get hot enough and quick enough.
I also understand it might be less efficent/economic to buy an overpowered boiler.
So it looks like I can keep 24kw and go for one of the Compacts - anyone have any thoughts on this?
The only issue is if I decide to get another 10 radiators and then I might be underpowered but this won't happen.
Next question is do I go for the 32 or 36 compact. Default answer seems to be the 36 - just because it has a higher flow rate and I believe if my mains is good enough then this will give me the best shower (do have good mains pressure).
I understand combies are not ideal for running multiple taps, but if you have a combi with a higher flowrate will this help if you are running a shower and someone puts a tap on?
Is there any other reason why it is better to buy the 32 over the 36?
Anyone have experiences of the Compact range? Search does not bring much up.
I have had a boiler guy around for a quote and he has recommended the 32 Compact for the following reasons. 1) fits in cupboard and 2) appears powerful enough. We did not really go into flow rates so I assume he thinks the 32 is good enough for a shower. I initally wanted the 34CDi but I think he has convinced me the Compact would be better (it being much easier to install in the space I want). I will be getting 2 more quotes anyway so can discuss this further but grateful for any views beforehand.
3 people live here but I also want to future proof it for potentially 5 in future (although not sure why a bigger boiler would make much difference as we woudl still have the same number of radiators and 1 bathroom - only thing I can think of is more demand on taps at the same time - hence a bigger boiler now will cover that issue).
Put the 36 in then you will never regret making the decision. All models run to suit their load so it's not like they run at max power when on. it chooses to do between 7 and 36 kw as required. It will not be any more to run. You are over thinking this quite alot.
I looked at Valliant but apparently they don't do one that fits in the kitchen cupboard.
If you are looking to future proof for an additional bathroom then go for a system boiler and an unvented cylinder if pressure and flow rates are good.
you say about over sizing boilers, a 24 kw boiler is well oversized for most heating purposes domestically .
a combi is sized on the hot water demand, bigger is better IF you have good enough flow rates. If you get a flow rate of 9 litres per minute then anything above a 24kw is wasted.
Why not keep the existing boiler location?
And why worcester?
Other than their tv ads and marketing :)
Ideal logic plus boilers have 7 year warranty, kitchen unit fit size and at lower prices.
more boiler for your money and comparable in quality at the middle of the market.
p.s neither the Worcester's or the ideals are my choice of boilers....
thats an impartial view :)
We went from a tank style system to a combi about 6 years ago - I thought combis were all the rage from an efficiency perspective.
Old boiler needs to be moved out of a bedroom to make storage space and I am doing the kitchen up anyway so it is ideal to move it into a kitchen and even mroe dieal to get it into a small wall cupboard.
As for Bosch - just chose them based on reading reviews etc. I've spent enough time I want a Bosch Compact that I am not going to reconsider another one! Plus I have made appointments with Bosch approved installers now. Either way I doubt Bosch is the worst and even if other makes are better I imagien the Bosch is good enough.
I'd never even heard of WB until I started looking into a new boiler.
In terms of future proofing I meant if we have more people - so more liekly to have someone using upstairs and downstairs taps as oppsoed to a whole new bathroom.
With a platinum installer they can offer you the 7 years the same as ideal but still, higher price tag.
35kw ideal will come in less than a 32kw compact by quite a bit.
a little food for thought :)
could be an idea to post up your location on here and ask members to get in touch to give you quotes.
WB are good boilers. Most of us plumbers are bias when it comes to recommending a boiler make and model tbh. WB will honor the warranty without issues (bar really bad installation) and wont sell your details to national companies. get it installed by a company that offers the 7 year warranty and wants to service it yearly for you. Normally if they are planning to service it for years after they will want to install it correctly.
you gas pipework will more than likely need upgrading to a larger pipe size also.
as for the output if your cold water suppply is good enough then go for the larger size. Its pointless going for a boiler capable of running at 14lpm temp rise when your cold is only coming in at 12lpm.
the installer can adjust the boiler in the software to suit the central heating demand to avoid it firing on full rate.
You out say you are basing your decision based on the reviews of the Worcester compact, there can't be that many out there as it was only launched 2 maybe 3 months ago so all the reviews on it will be good as nobody has had to live with it long term. I also wouldn't go too much on reviews of it's older boilers as this is a completely new design,
but as you've said it's what you want and I admire you for sticking to your guns
I wouldn't buy a boiler based on it fitting inside a standard kitchen unit, if the installer fits a magnetic cleaner under the boiler it will stick out any how, choose whatever is recommended by the GS engineer that looks at your property then order a large cupboard from the supplier or custom make one to fit.
Also what KB is saying is the best way to go if you have the flow rate and the room for an unvented cylinder. That's just my opinion.
We have fitted hundreds of em in all guises, WB CDI Classic every time, alter your cupboard!
Some gsr guys love wb some hate them,some points to note
Plus points
Wb have a great backup service
Well known brand
Long warranty if serviced correctly
Negative points
Built with lots of plastic parts
If they go wrong not easy to work on which could cost more to repair out of warranty
Overpriced compared to other manufacturers
If there's a chance you may not get your new boiler serviced every yr then the warranty will be void personally I would go for an ideal logic easy to work on and made with brass/copper ect very little plastics to go wrong and cheaper to buy.
Personally I'd go with Worcester I have never had them not fix a boiler if required under warranty...
The best warranty is the one you never have to use.
I'm not a personal lover of WB but I fit a lot on a contract basis. I would agree with northcarr and vern. Their service is generally very good, which is where the price tag comes from, as opposed to other manufacturers who don't offer as good a service, but who's product represent better value for money. Also the classic CDI is a better unit. Not to keen on the compact and I think I would slit my wrists if someone wanted me to repair one! They remind me of a duvet in one of those vacuum packed bags, no space !
Bigger boiler output means bigger gas supply, as you have to provide the correct gas rate on full rate regardless.
i would be inclined to research Ideal Logics range before settling on a Worcester, but out of the two models, the CDI Classic is a better product, tried and tested etc.
Funny that. WB give good service on gas boilers because my experience on the oil side is dire.
I did say generally, although to be fair they have always been ok to me for oil. Probably more to do with regional management rather than technology.
fitted about 4 of the 36 compact CDI , what can i say I have fitted one last friday too and they are just the one to go for !!!
customer service to back this outstanding boiler second to none !!!
there is no other boiler manufacture to compare there customer care with Worcester Bosch in UK
same bar one they installed and didn't do the conny up. Came out and replaced the lot.
i haven't got any gripes with the back up from Worcester on the gas side though.
Where does the magnet thing go? I believe there will be pipes comign out of the bottom of the boiler - but these can be boxed in.
Trouble is if you do a search you get good and bad for any make - with WB and with Ideal.
I will discuss the CDi with the next guythat gives me a quote. I have to consider the considerable cost and hassle of putting it into the ktichen as I woudl end up losing cupboard space - also the piping and electrics will be a lot more complex and it would have to go into a place that does not have a direct line for gas and electric liek the Compact would (i.e if I go for Compact I can put a straight gas/elec behind the units but if I go for the CDi we will have to look into taking the ceiling down to bypass pipes going all the way aroudn the kitchen and so on.
That si not to say I wouldn't go for the CDi but need more convincing it is that muc better.
Yes, no proper reviews for the Compact - most reviews abotu other Worcester Bosch's and the brand generally.
I'd put boiler choice above cupboard space in the matter of importance TBH ;)
Apparently, if you have a water meter in the property you need an expansion vessel on your main otherwise the guarantee means zilch.
worcester = hardwork an headaches if you ask me !!
water meter = non return
when the hot tap gets closed the plate hex still absorbs the heat and the water expands, no where to expand to by design without a small expansion vessel (shock arrestor)
I think viessmann and atag have built in expansion vessels for this purpose
not it hard at all just get a shock arrestor an fit under boiler, tiny little things. Or fit anywhere on cold main.
Point taken - it was the Bosch boiler guy that was really pushing the Compact on me - he reckons it is as good as the CDi and saw no reason why I shouldn't go for the Compact (I did explain the cupboard issue though so he took that into account).
I will see what the next guy says. A secodn view is always good.
Before said guy came the CDi was in my mind as it appeared more pwoerful but having looked into it, the Compact 36 has a higher flowrate and will do my central heating.
The downside for the Comapct seem to be it may be more difficult to work on and it is not tried and tested (but been out for about 6 months only).
Stop getting to manyan in ! You will get lost . Stick to what you have seen so far .....
it ain't going to tell you something that you have not read here already
baxi are a mixed bag,in wales if your a works member next day guaranteed xmas day and boxing day excluded,they have not let me down in 8 years and the rep is excellent and a duotec HEA will outlast any worcester shame it wont fit in a cupboard,they come in outputs of 24,28,33,40 kw and have a 7 year warranty as standard parts are reasonable after the warranty expires as well and very easy to work on in my book thats valiant and Worcester out
I have fitted a duotec in a few cupboards. And still met clearances (just) did one the other day had to remove a protherm 80e duotec in the same spot. Only 5mm difference in size.
But any how another vote for baxi over here
Reply to Boiler queries - Worcester Bosch Compact in the Plumbing Jobs | The Job-board area at PlumbersForums.net
