Discuss BOILER MAKIG NOISES.. in the Gas Engineers Forum area at PlumbersForums.net
Hi, my newish boiler has started making strange noises every hour or so. i also only have 50% of y radiators working even after iv tried bleeding and balancing. hoping that someone on here can give some advise before a plumber visits.. thanks in advance, Kim.
  • 313915184_5577879182328327_8266557629994249396_n.mp4
    779.2 KB
Overheating you haven’t drained the system have you ?
i had a new radiator replacement last week, ever since only 3 out of my 6 radiators are working ( 1 upstairs and 2 downstairs are working, the rest are cold). the plumber did drain the system to install the new radiator.. does it mean the system needs to be topped up, ? im hoping a plumber will visit tomorrow,, thanks for your input,, Kim.
I suspect air locked plumber didn’t do his job eg should of run / heater the system up and bled all of the air out / made sure it worked
iv bled all the radiators and no air was coming out only cold water. bit of a mystery. the plumber that installed the radiator wasnt interested to stick around to ensure all the radiators were working.. im using another plumber in the future..
I suspect it’s above the boiler /filter eg goes up and then down
You could try hot water only and turn the heat temp dial down to min and let it run for all night and re try it in the morning eg on heating
Reply to BOILER MAKIG NOISES.. in the Gas Engineers Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
