Discuss boiler call in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauls
had a call today from a customer when he turns the boiler off it still heats up and he can hear it bubbling.
im thinking bypass valve or maybe stat aswell
not a lot to go on, but i'm not thinking bypas or stat, i would be looking at faulty zone valve
it wasnt explained to well and the bloke has a really bad stutter from what i could make, when he turns the boiler off its still heating up, boiler is a combi
If combi would say maybe,hot water flow switch stuck :(
As for stutter,if he tries slowing down his thoughts and speech,this sometimes helps ,cover all areas here!! :)
Reply to boiler call in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
