- Messages
- 17
I need to drill out a 32mm hole in a stainless steel bar (4 - 6mm) What is the best type drill bit for a normal combi 18v drill.
Discuss Best drill bit for stainless steel in the Plumbing Tools area at PlumbersForums.net
Hss very slowly with plenty of oil start off with a small dia and work your way up to about half dia, then go for it , nice new sharp drill loads of oil. How many are you doing ? there are electro magnetic type bench drills you can hire for site work. centralheatkingTct but you can make do with a bi metal hole saw and some cutting oil but speed 1 and take your time prob around 20-30 mins a hole
Ok cool thanks I like the sound of this. So basically a hole saw but for metal instead of wood, and then you get different sizes instead of just one.Tct but you can make do with a bi metal hole saw and some cutting oil but speed 1 and take your time prob around 20-30 mins a hole
mate it’s just one for a monobloc tap.Hss very slowly with plenty of oil start off with a small dia and work your way up to about half dia, then go for it , nice new sharp drill loads of oil. How many are you doing ? there are electro magnetic type bench drills you can hire for site work. centralheatking
[automerge]1576523289[/automerge]
Yip IllYes will be listed as bi metal go Bosch or starrett
Get two not just one incase you hit a hard spot
have you ever used a step drill , this type of thing. No idea if it’l just meltYes will be listed as bi metal go Bosch or starrett
Reply to Best drill bit for stainless steel in the Plumbing Tools area at PlumbersForums.net
