Discuss Baxi Platinum Combi HE 28 - no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
D4Daz2107
Hi, 1st timer with a bit of Boiler DIY knowledge built up from owning an old Britony 80 ahhhh!
My Baxi platinum is 18months old and yesterday the DHW gradualy stopped working till now it does not work at all, SO no HOT WATER.
CH is all OK, the following is what I see:
Run the tap, Green Light illuminates.
But no burner flame
Hall effect sensor lights red, water pressure feels OK
HELP!!!!!
Regards
Darren - showering at work- Scott
Warranty, yes it is under warranty and I have called Baxi and they are going to send out an engineer however I was reading on another website that I may not have a warranty unless I had been getting my book stamped up. The boiler was serviced a year ago when I had all my radiators fiited with valves, the system was flushed, inhibted etc...the inside of the boiler was cleaned, filters checked etc...but I was not aware that I needed to get the book stamped so I have tracked the guy down who serviced it, but he works for the council as a plumber and for some reason he would not commit to signing up the book, so at the minute I maybe stuffed, any thoughts???
Regards
Darren
Do you have any other dated paperwork?
Servicing schedule, invoice etc.
I attend in warranty breakdowns for boiler manufacturer.
As long as the benchmark page was completed on installation and the problem is within the boiler casing I would repair.
If the log book had not been kept up to date then I let the customer know that not everyone would carry out repair.
It will be the attending Baxi bloke who decides to repair or not.
Thanks for the replies JAP&H, wish you lived up this way, my thought process is along the lines that a yearly service of cleaning filters etc would not prevent equipment failures of sensors, motors, pumps etc...maybe I am wrong to think like that.
Do you have any ideas what could be wrong so I dont get ripped
Does the boiler work in heating mode?
If hall effect sensor checks out, next thing is diverter valve and actuator.
most Baxi guys would just sort out the problem,they are more keen on promoting brand values than some other manufactures,bit confused as to why the op wants to avoid getting ripped off if the boilers in warrenty
This highlights one of the issues in getting someone doing a foreigner to service your boiler. Baxi should still honour the warranty but if there's a fault due to the previous guys work there'll be no comeback on him because nothing is in writing.
I have found the complete opposite. Heateam have been the worst at trying to dodge fixing a boiler under warranty that I have come across.
Reply to Baxi Platinum Combi HE 28 - no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
