No Shawn, NOT solid at all.... rapid flickers. SHOULD it be solid?Is it making a solid red light when waters flowing ?
Also if you live in a hard water area then yes I would clean the screen
Obviously have to turn off the incoming water. But will it back-siphon all the hot water from the lines above this level?Yes should be constant sounds like the flow sensor is getting old part no 81
