Discuss Baxi boiler just installed.... gurgling sounds. in the Central Heating Forum area at PlumbersForums.net
M
Max Thomas
Hi. New Baxi 619 heat boiler installed last week. Type with a hot water cylinder.
Lots of water / gurgling sounds when hearing switched on. Plus the boiler ignites and stays on for approx 10 minutes then switches off. Then comes back on after a few minutes.... this cycle repeats.
Any advice please?
Chances are there’s still air in the system circulating round did the installs tell you to check your system in a week and maybe top up the pressure if sealed ?
Reply to Baxi boiler just installed.... gurgling sounds. in the Central Heating Forum area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
