Discuss baxi 105he hot water issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bigrab2203
your probably sick being asked about this but help would be appreciated!
baxi comb 105he around 10 years old in my daughters flat se just moved in and has heating but when you turn the hot water on it comes through hot but quickly goes cold and the temp lights drop out one at a time then it turns off!
there are a few things apparently ie diverter valve, heat exchanger, heat limiter sensor any ideas? thanks
sorry to say unless your gas safe you cant do much and most of them require taking the case off which you cant do
best advice get a heating eng out
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
are you not allowed to close threads yet AP?
I am not doing repairs but the gas engineers first words were "oh that's an out dated system it needs a part ill see what I can do" no information nothing and its been a week and a half I do all the maintenance other than the gas so wouldn't touch the boiler I just want to be sure he's not ripping her off is all guys
I have no intention of attempting any repairs to the gas system I do the maintenance for the landlord and just wanted to be sure the guy isn't trying to rip her off
Reply to baxi 105he hot water issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
