Stu292
Since I installed this boiler I thought I knew all it's quirks and but this one has me stumped.
The DHW is working fine, endless hot water.
Central heating fires up, radiators get warm boiler reaches 50 degrees and shuts down as if it's reached the correct operating temperature, pump continues to circulate before shutting off as per normal procedure.
It has a wireless thermostat which I can place right next to it and watch it do it's cycle. Even though the boiler has switched off at 50 degrees the thermostat continues to try and tell the boiler to continue to operate as the thermostatic room temperature has not been reached. Thus when the boiler has completed it's cycle it gets the signal from the thermostat fires up again heats up to 50 degrees shuts down, pump runs and so on.
I thought it might be the thermistor so have replaced that but it's still the same.
Nothing has been touched or changed prior to the fault, it's been fine since the last service a year ago.
Stu
Stu
