Silvana
Hi can anyone help as my heating engineer has come to a dead end. The heating on my boiler (Baxi combi 105E)only reaches 50 degrees which leaves the radiators warm but not working at full heat. The hot water is fine, it actually reaches the maximum temperature on the boiler of 70 degrees but the heating won’t go any higher than 50 degrees. I do not have radiator thermostats or a room thermostat and the pressure on the boiler is fine, as is the pump. The radiators have been bled and some of the radiators been taken off to check for sludge but they were clear so it doesn’t appear to need a powerflush, it’s just that the heating won’t go any higher on the boiler than 50 degrees (as per the display panel) when it should be able to reach 70 degrees. One of the radiators was also taken off to see if that improved the heating but it didn't. Has anyone got a suggestion as to what the problem can be as my heating engineer and I are at our wits end!
Silvana
Silvana
