Discuss Battery operated sensor taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
R.Oak
Ive been asked to replace 12 mixer taps with sensor taps in my local doctors surgery. Ive been looking at the ones that run on AA batteries rather than wired to the electrics. Does anyone have any experience with these, are they any good?
They work ok but will obviously require batteries changing, also often only work with decent pressure - check manufacturers litetature and dont go as low as minimum always look at reccomended pressure.
How do these taps work if the batteries go flat or do they just stop working? If they just stop working I'd be installing 3-4 taps at a time a good few weeks, maybe a month apart so they don't end up with all the taps packing up at the same time. Yes I know they could change the batteries but the doctors that I look after asked me to change a light bulb the other day!
or even better use the electric ones
Or offer to add it to your annual/biannual service - for a price!
Reply to Battery operated sensor taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
