Discuss Bathroom tap no cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tristan Kinslow
Hi.
I'm trying to work out why there is no cold water coming out recently from bathroom mixer tap. Hot water still works fine.
Im stuck on working out to unscrew tap head to try changing the washer in the hopes it helps.
I've attached an image of the tap mentioned.
the tap feels normal when turning on and off and takes a few turns to go from fully off to on. There is cold water from the bath tap still.
I have not changed anything over time, it just gradually got worse until no water came out.
It is not a cartridge but a traditional mech.
As that is the case it is unlikely to be the tap. I suggest removing the valve, putting your hand over where the valve goes and get someone to turn the water back on SLOWLY. If the water flows freely then it is indeed the valve. If not, then its elsewhere.
Reply to Bathroom tap no cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
