Discuss Bathroom tap no cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tristan Kinslow
Hi.
I'm trying to work out why there is no cold water coming out recently from bathroom mixer tap. Hot water still works fine.
Im stuck on working out to unscrew tap head to try changing the washer in the hopes it helps.
I've attached an image of the tap mentioned.
the tap feels normal when turning on and off and takes a few turns to go from fully off to on. There is cold water from the bath tap still.
I have not changed anything over time, it just gradually got worse until no water came out.
It is not a cartridge but a traditional mech.
As that is the case it is unlikely to be the tap. I suggest removing the valve, putting your hand over where the valve goes and get someone to turn the water back on SLOWLY. If the water flows freely then it is indeed the valve. If not, then its elsewhere.
Reply to Bathroom tap no cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the upstairs taps, I have a combi boiler and no water storage
Mike Young
M
