Discuss Bath trap/waste options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone,
I am putting a bath into a bathroom with limited ceiling height so am trying to get the bath as low as possible. Currently the bath waste will be at the height of the plywood floor which means a bigger hole and less structural support. Ideally I would like it to be below the floor, reducing the hole size in the plywood to just the pipe diameter, and allowing the waste pipe to run under the floor too.
The question is- can I add in a small (say 6"/150mm) vertical drop between the bath plug/waste and the trap?
Another issue I will have is once under the floor, to get around a joist without drilling any holes I will need to drop a further 6"/150mm over approx 3'/900mm, after which it will join a regular drop (approx 1/80) waste pipe.
Are these steep drops OK for short distances or is this an obvious mistake?
Thanks in advance your your help!
The bath is to replace a shower which I've already taken out but here's what is left. The shower was connected under the joist via a flexi pipe shown. I intend to replace the flexi with solid pipe but need to run this for a length until it is below the joist. Forgive my artwork but I've tried to draw a representation of what I had in mind as a solution (the perspective just to show drop etc- the bath actually runs perpendicular to the 3''x9'' joists). Ive also attached some pictures of the new bath and feet arrangements to show how the trap wil be at floor height unless I can find a solution. Thanks for taking a look!
why not use one of these?
Interesting. Would that run vertically down then? (I’ve only got about 45mm between the floor and bath so if it’s thicker than that it won’t fit horizontally)
yes vertical approx 50mm dia
trap
adapter
will fit straight onto the bath outlet dont buy them from my links go to your local plumbing merchants be a bit cheaper
Depends how your doing it
Vertical it should screw straight onto the bath waste
Horizontal you need the adapter which screws onto the trap and then goes onto the bath waste
Hope it makes sense
Reply to Bath trap/waste options in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
