Discuss Basin fixing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dannyparty92
Hi all, can I use plasterboard fixings on a stud partition wall to fix a basin? I said it would be better if there was some timber to fix to but customer doesn't want the hassle of ripping board of and fixing timbers. Thank you
Unless it comes with a proper wall fixing bracket for wall hung basin, then I wouldn't advise using plasterboard fixings. A plywood section behind the plasterboard is the strongest option. Tell your customer that if he wants it done right so that it doesn't fall off the wall, that it has to be done this way. If not, I'd refuse the job, don't want it coming back on me after telling the customer how to do it properly.
Armitage Shanks S915067 NA Wash Basin Concealed Bracket Assembly
No problem if it's on a pedestal, just remind the customer not to swing on it.
if your gentel you could cut the board and get a small bit of timber in.
if not use spring loaded toggles and half a tube of stick like a-good-en.
Is that bracket only for commercial Portman basins?
Not sure if it works very well in a household environment.
would be better to do a little tricky keyhole stuff. Mark the outline of the basin on the wall and slide bits of 9mm ply into slots in the plasterboard within the marks. Hold the ply in place with screws through the plaster board and either fill over the screw holes or put a small tiled splash back above basin. Tricky but can be done with a bit of patience
If it's on a pedestal, then using good fixings will support it. I hate silicone on the back of a basin as it makes it difficult to remove.
These are my favourite PB fixings and are very strong. Use a 8mm drill bit and put a blob of silicone in the hole to strengthen it:
Fischer Plasterboard Plugs HDF 4mm (8ga) Pack of 100 | NoLinkingToThis
I expect the customer wont want a flood at xmas when the kids hang off the basin to brush their teeth! Do it well or not at all is my motto, if you slide in a noggin basin covers most of it and plaster is easy to make good
They fit most small cloakroom sized basins. The OP didn't give much information in his first post.
I had only used them on Portmans before. Fitted literally hundreds of them at the Torness workers camp about 30 years ago. Don't think I have touched one since
I think il go for the twist in plasterboard fixings and silicone. Thanks everyone
Infact I don't know what I'm thinking. Im just gunner cut some board out and fix a horizontal stud and fix to that.
Reply to Basin fixing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
