Discuss Balancing Problems Since Drain and Refill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Since drain and refill of our gravity fed system I cannot get heat to alot of the downstairs rads. One downstairs rad is boiling but turning that off doesn't have any positive effect.
Most of the upstairs get nice and warm but if I turn off all of the upstairs rads then the boiler simply turns off instead of pushing heat downstairs. Boiler only gets call for heat again once upstairs are turned back on.
Any ideas please. Thank you
is the system zoned or perhaps a valve closed some where on the downstairs circuit
also sealed system or open vent?
If its open vented you could have a bad airlock in the downstairs circuit
If the above suggestions aren't the answer, you're left with 'sludge' blocking the downstairs circuit. Easily washed down in the draining process if you weren't very careful. Assuming the pipes are copper (or plastic) you may have some luck locating the blockage with a strong magnet.
Close the cylinder return gate valve, close all upstairs radiators, turn the boiler temperature down so it doesn't lock out.
Put the heating on, the pump should circulate around the downstairs circuit and push the air out. You might want to close all but one of the downstairs radiators then open them up one by one as they get hot.
I'd be listening for air moving around the system and watching the vent pipe over the tank to see if it pumps over, if it does your looking at sludge in the downstairs circuit.
If nothing happens I'd be checking the pump
Too be honest your getting into heating engineer territory
I'm guessing that the value bottom right is the cylinder return. Thank you.
Reply to Balancing Problems Since Drain and Refill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
