Discuss Ariston clas 30HE - 2 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sim77
Hi all,
Could someone help me out here please? I got 2 errors on Ariston clas 30HE.
Error 1
It shows 201 - manual says - DHW sensor short circuit / open line. Had a look where the sensor is supposed to be just to find a blanked off port and loose sensor wire. Boiler works fine though, just shows error 201 (???). Could it be possible that there are models without DHW NTC but this one has a wrong board fitted? Pictures below.
Error 2
If I take a cover off to get to gas valve the boiler ignites but fails to rectify and goes to error 501 - flame lift off. The same happens when flue gas test point is opened. Tiny bit extra air and it goes into 501. CO2 and ratios are fine with cover on and FGA probe in. Take the probe out goes to lock out.
Anyone can help with those 2 faults please? I could not ring technical on the weekend.
Thanks!
Hi all,
Error 1
View attachment 22828View attachment 22829
Error 2
Thanks!
not sure on fault one,fault 2 sounds like flue issues,can you get it to run long enough to do a flue integrity test?
Fault two sounds like breathing problem with the flue or Venturi , it mightn't be anything obvious blocking it just a buildup of of grime or dust.
Reply to Ariston clas 30HE - 2 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am currently having issues with an Ariston Combi A series boiler giving an E08 - "No water in primary circuit" error code, the circuit is...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
