Discuss Anyone recognise this PRV? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
Would rather not alter pipework if possible!
Thanks!
boss vessel kit mate
Boss, althecnic, and flamco pretty much the same. All 1/2 BSP male,
Reply to Anyone recognise this PRV? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a PRV located in a heated plant room that is between a pair of stop cocks. It was installed to keep pressure under 3 Bar a couple of years ago but I have noticed an area of verdigris on the piece from the main body to the gauge. I wondered if this might be sign of a leak / trouble or...
This bath filler/overflow is supposed to turn to divert water flow to a shower above. It’s not clicking across anymore. Does anyone recognise it? Fitted in 2014. It was installed together with this Bristan inbuilt thermostatic controller.
Deleted member 120897
N
Hi, I am not a plumber but want some help finding at what torque at which the PRV's bell housing screwed to the valve body. can the plastic bell housing pop off the main valve body due to pressure or unscrew itself due to prolonged water hammer effect? PRV: Wilkins Zurn NR30 40mm 500kpa
Nik Tribhuvan
N
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now connected to the mains water feed supply and the water tanks in the attic have been disconnected (each flat has a combi gas boiler). My question is the...
1K
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
