Discuss Any tips on getting half a snapped van key out of ignition? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ok!.
the best way to extract a key is to make a simular item to a locksmiths pick.
get a set of feeler gauges and trim down the thin one (or work your way up the set to one that suits) with a pair of scissors. cut the blade so its the right width then barb the edges slightly.
the idea is to slide the blade into the lock along side the key. the barb will catch the key and extract it. good luck.
Bit of epoxy resin glue on a thin allen key, wait to set and hey presto. Like Redsaw's way as well.
Well I'm torn between a) the glue on a thin thing or b) leaving it be.
How likely do we think the chances are that the half a key lodged in the ignition and the half a key sitting on my bunch of keys - which have, together, successfully started the van first time every time for last week of usage - will suddenly stop working while I'm stranded somewhere?
.............and don't forget, not only will you be miles from nowhere you will have no mobile signal either. :)
Reply to Any tips on getting half a snapped van key out of ignition? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
5K
Hello All I've been having fun with my old vented, Y-Plan central heating system, since I finally got it up and running again yesterday, having...
4K
Okay. So I have a ground floor shop and second floor flat for sale (potentially). No major need to get shot of them, but not a lot of point...
Had a job booked in this morning, renew all rads in the property. Downstairs rads are in solid floor so customer said just change rads and alter...
