Discuss Air admittance valve black in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
maxthedog2014
Hi Guys,
Just a quick question, I understand the external soil stack regs for a open vented, my customer wants me to fit a air admitance valve on her new stack which i'm putting up. It will be external inbetween two windows . my question is do i have to go past the guttering, for some reason i'm thinking it only has to be 1m above flood level eg bath? Thanks for your help on this :)
Doesn't need to go above gutters about 6"-12" under soffits is fine
But be careful some aav can only go inside get one for outside
If its A1 designated it can be fitted bellow the flood level aswell, if you are going to run it up past the guttering you may aswell vent the stack instead, if its within 3m of an opening vent 900mm above it.
Reply to Air admittance valve black in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
