- Messages
- 7
After flushing, there is only a trickle of water entering the tank. When I turn the valve off, and then on again, it flows normally again. The upstairs toilet and all other faucets work normally.
Discuss After flushing, there is only a trickle of water entering the tank. in the USA area at PlumbersForums.net
The shut off valve at the wall that connects to the line going to the tank.Err, which valve are you turning off and on again please.
Thanks for the reply. I just shut off the valve and disconnected to hose from the tank. Then I placed it into a bucket and turned it back on. The water pressure is strong. It seems the problem may be the fill valve. Could that cause it to trickle after the flush? I notice when I don't let it flush completely, the water continues to flow into tank normally.Then there must be a restriction in the said valve or pipe .
Thanks for the reply. There are no kinks in the braided hose. I turned the valve off and on several times, but once the toilet flushes, it goes back to a trickle.If there's a flexible pipe - braided steel then check for kinks / twists.
Try turning the valve on and off a few times.
(Switch it off and then on again)
All done! Thank you, that solved it!I'd try replacing the float valve at this point. Use a good quality branded replacement such as a Fluidmaster Pro (with a brass shank) or Pegler Yorkshire.
It's unusual, but it is possible for a foreign object in the pipework to be responsible for the sort of behaviour you describe. Never experienced it myself but have heard war stories...
Reply to After flushing, there is only a trickle of water entering the tank. in the USA area at PlumbersForums.net
